Two LED's Added to the Grill
Deinonychus
Jacksonville, FL
As you know the Raptor comes with three LED's at the top of the grill. I had seen where someone in town had added four OEM LED lights to the bottom of the grill.
I sought to go a slightly different direction and added two OEM LED's to the top of the grill, outside the stock three. Lack of proper communication had the shop placing them one rectangle inside of where I asked them be placed. And yes, I am disappointed, but it still looks pretty good to me.
It requires the use of a dremel tool to enlarge the rectangles to accommodate the OEM LED's. The two were then epoxied in place.
Here's a couple twilight pics:
J-train
Vandenberg, CA
You took it to a "Shop" to do that? Seems like a pretty simple mod to handle, but it looks kinda cool. I would assume they just spliced right into the stock wiring. These are LED lights, very low current draw, I am sure you could easily double the amount of lights without causing and issue to the stock circuit.
Deinonychus
Deinonychus
Jacksonville, FL
Will you elaborate on how you wired the new lights?
Spliced into the stock LED grill wiring.
Removed the grill from the truck. I also attached Custom Truck Shop raw aluminum grill letters with 4mm hex head bolts, which was also easier to accomplish with the grill removed.
pat'sRAPTOR
Everywhere
Nice I really like the grill letters they look a lot more durable then a sticker or something that uses double sides tape!
dataustin
Are there any DOT requirements for the number of lights on the front of the truck?
Deinonychus
Deinonychus
Jacksonville, FL
I hope that I haven't exceeded the number.
---------- Post added at 10:25 PM ---------- Previous post was at 10:22 PM ----------
The shop's owner had cut, fit, and glued the OEM lights in a previous customer's Raptor. It wasn't worth me mis-cutting the rectangle area. Plus the grill letters were there getting Line-X'ed.
TheJoker
N. E. Massachusetts
It would be really cool to add two more at the bottom of the grill directly below the two you added, then have the four additional lights hooked up to a strobe/flasher unit. Alternating between the top right / bottom left and the top left / bottom right.
93,363
56,644
LDMiles
