Its not looking good boys...
FordTechOne
Detroit
Alright - diag suggest bad crankshaft.
FKING DAMN IT.
1. Tear engine down and rebuild -$7k
2. Pay for used middle mileage 3.5 eco, $3-4k, $2500 to install, STILL 7k.
Thoughts? Anyone close to MD that can do the install for less than $2500 or have access to good used low mileage engines? If the engine is coming out what else should I consider?
“Bad crankshaft”? :rolleyes:
So it was brought in for a phaser noise, right? How did the crankshaft become “bad”, and how are they determining that?
This shop sounds more suspicious with every update.
nikhsub1
Los Angeles
Well, he had phasers done before I think. If a certain bolt isn't torqued correctly, isn't this what can happen?
Donovan
DC
Well, they want to tear it down because they suspect that it is the crankshaft. Great shop, they are just trying to figure it out you know? Not knocking them.
BUT this website makes my heart feel better - https://fraserengineco.com/3-5-liter-ford-ecoboost-engines/
Seemingly brand new engine with all TSBs/upgrades done.
Now who wants to install this shit?
FordTechOne
Detroit
If the crank bolt isn’t torqued correctly it will damage the crank gear. Which of course is a workmanship issue. But that can easily be confirmed, they’re stating “diagnostics suggest” a “bad” crankshaft. None of that adds up.
yeah, so I’ve heard. Not a club I want to join.
julien194b
Europe FR.
wow, I am surprised how a complete block is so affordable...less expensive than a complete set fox or other aftermarket suspensions kit...Who are the scammers :emotions33: ?
someday
wisconsin
they still cant figure it out?
if everything has been changed in the front and it sounds like it coming from the bottom then its prolly a rod bearing so it will prolly need a rebuild or reman. if the front cover is still off might as well drop the plastic oil pan and inspect the lower end. maybe even do a compression test
Sounds like they still didnt drop the oil pan yet.
