bosssho
So about 2 years ago I got the R1 Concepts Full Slotted/Vented Rotor/Pad Kit from a Forum Vendor. I also got the Stainless Steel Line Kit. I tow semi often (sleds, ATVs, UTVs) so I wanted the best brakes I could get that would fit under the OEM 17" wheels...
Upon initial installation I was "happy" but not "thrilled." Braking felt good, but not blow me away great. My definition of great brakes are brakes that you don't have to get way into the pedal to have a good solid braking feeling and more importantly results taking place.
I was happy with the OEM Raptor brakes...not sure if they are better than a standard F150, but again, I wanted better.
So about 6 months ago I started noticing increased pedal effort and depth to achieve braking, and I let it go until the weather got nicer and things slowed down chaos wise with winter sports, and brought the truck back to the shop that installed the R1 Brakes. They are friends as well as a shop so NO BS goes on. They found all 4 Rotors to be in great shape, as well as all the Pad to be wearing evenly. None of that was a surprise as I do NOT get any vibration or issues like that...just NOT good solid braking/stopping.
So I called the Vendor on here who I got the brakes from...he said to bleed the brakes. We did. Zero difference. I called him back...he said w/the synthetic DOT3 fluids to have the Brakes fully flushed and filled and bled like a Radiator with a Fluid Flush and Fill. This is a major ordeal in the sense that a dealer has to do it b/c of the computer involvement with the ABS system and the whole rigmarole. I am friendly with the dealer so they set it up, and the Serv. Mngr is familiar with R1 Brakes b/c of the GT500 guys using them too, so he got that all done. Zero difference as well...brakes still suck.
So now the Truck is going back to the dealer (My NAV keeps losing its way too so that needs to be readressed) on Monday, but I am reaching out to you guys for any help and advice...PLEASE lay it on me if there are things to check, known issues, etc, etc.
Thanks as always for any help and advice.
