Parking Brake Alert Malfunction - Help
Don S
Moorpark, Ca
I have a 2019 Raptor with about 27K miles. The other day while driving on the freeway, the dash lit up and said Parking Brake Malfunction. I got a picture of the wrench, the dash display told me multiple things were now unavailable, including changing driving modes. I thought the world was coming to an end. o_O I pulled over, shut everything down and restarted. It was still there. I shut everything down again,open and closed the door and locked the truck. I unlocked it and started it up again. No malfunctions. The truck drove fine.
I few days later, it did it again as I pulled into my driveway. I followed the same procedure the malfunction lights went off. The only thing that has been done....about a month ago....I replaced the front brakes and rotors.
I did a search on here and the internet and could only find a parking brake issue that people were having back in 2015.
If I can't figure it out, I have no issue taking it to the dealer, but I like to go in with as much information as I can, so I can speak intelligently about the issue and get a straight answer.
Any help is appreciated.
TomDirt
Hesperia CA
My 2012 3.5 ecoboost does that from time to time at highway speeds. I just used my foot to "pull" the parking brake pedal as I pulled the handle.
Old-Raptor-guy
USA
Yea, that isn't the same.
2019 up f150 have electronic parking brake.
To the OP. Check that both rear caliper electric parking brake actuators are plugged in. Specifically the drivers side. The drivers side needs a shield if you ask me. Twice in off roading applications an object (rock) has flipped up and pulled the wires out of the drivers side connector on mine. The wires snap back in and all is good.
And yes, this shuts a lot of functions down, which is relatively stupid, considering it is a parking brake issue and not an actual braking issue.
Ruger
Northern Nevada
If indeed that works (also opening and slamming the driver's door), then it points to the parking brake sensor/switch that tells the CPU that the parking brake is set. Find, inspect, replace or adjust that switch and it might well solve the problem.
Old-Raptor-guy
USA
NOPE TRY AGAIN. THIS TRUCK HAS ELECTRONIC PARKING BRAKE.
Don S
Don S
Moorpark, Ca
Thanks everyone for the help, especially Old Raptor Guy. I'll check the wiring harnesses. I guess I could be Old Raptor Guy too, I'm 68 years old and just like the truck as a daily driver. We also tow it behind our diesel pusher motorhome.
