Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Anyone have Raptor Computer Network Woes
This is a discussion on Anyone have Raptor Computer Network Woes within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by Aaron If you got that as a rental, would you show people....Uranus? Without doubt....
Like Tree26Likes
Old 12-05-2017, 06:16 PM   #21 (permalink)
Smokeshow60's Avatar
SgtMajor of the MemeCorps
Without doubt.
Smokeshow60 is offline   Reply With Quote
Old 12-05-2017, 06:17 PM   #22 (permalink)
Dildo Schwaggins's Avatar
Junior Member
Who wouldn't?
Smokeshow60 likes this.
Dildo Schwaggins is offline   Reply With Quote
Old 12-05-2017, 06:28 PM   #23 (permalink)
Aaron's Avatar
Meme Corps Commandant
Originally Posted by Dildo Schwaggins View Post
Who wouldn't?
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 12-05-2017, 07:27 PM   #24 (permalink)
If you have a rental, 30 day rule does not apply in many states. Trust me.
MJslasherADMIN is offline   Reply With Quote
Old 12-05-2017, 08:44 PM   #25 (permalink)
When you have multiple codes like that usually the first code that comes up is associated to the module taking out the whole network. The other cause is loose wiring on one of the connectors or even broken ones. Have to be on the look out for mice when it gets cold out. They should be able to view the network activity with a scope and wiggle some stuff around to see when it drops. It can be a tough job but shouldn't take days.
lightman02 is offline   Reply With Quote
Old 12-05-2017, 09:13 PM   #26 (permalink)
Multiple codes like what?
Old 12-05-2017, 09:26 PM   #27 (permalink)
When you have multiple lights coming on and loss of control to certain things in the vehicle there will be multiple codes generated for all the failures in various modules. Even the power windows and locks have a module in each door that controls that function, they all talk on the same network and all generate failure codes. These codes cannot also be read on a normal OBD2 scanner but Forscan can probably read them. When you have a network or electrical failure a bunch of codes will generate for each module but finding the wire or module pulling down the whole network is tricky. These devices are all connected together in a loop, they are not isolated like normal Ethernet networks. Finding the module or wiring effecting these systems is a pain in the ass. But you usually start with the module that threw the first code in the list for good practice.
Old 12-05-2017, 09:36 PM   #28 (permalink)
Do you think the dealer that told the op that there was a "network " problem could read codes with ids? Don't you think they would tell him before coming up with a story like that. And btw all sorts of codes coming up from everywhere is usually ecu failure.
Old 12-05-2017, 09:42 PM   #29 (permalink)
No, I don't think a shop is going to list all the codes for the customer, yes they can either read them or they can read nothing. Also multiple codes is not always ECU failure, ECU failure is actually pretty rare.
Old 12-05-2017, 09:51 PM   #30 (permalink)
So you think a dealer is going to find a bunch of codes then not relay that information to the customer and instead make up a story about a network issue? Sounds legitimate. And ecu failure is a much more common diagnosis for "codes coming from everywhere " than one "first in line " failure as you stated.
Tags
dealer, raptor, repair
Single Track Woes KaiserM715 Recreational Land Use Issues 0 05-21-2014 12:30 PM
Ordering woes CupcakeDestroyer Prospective Raptor Owners 7 01-08-2014 11:39 PM
TRR and Childrens Miracle Network treypal Upcoming Expedition Announcements and Planning 12 03-01-2013 12:27 PM
Line-X Woes WildClyde Ford Raptor Exterior Modifications Forum [GEN 1] 7 01-19-2012 11:42 AM
