Your Raptor and It's Alignment
SCSVT
Carolinas
OMG what a fantastic write up. Very interesting on the hard evasive braking, I always assumed it was "hits" that would take it out of alignment. Saving this...
Phoward0032
Elizabethtown, KY
That really depends where the camber angle sits now. If camber was between 0.4-/+ degrees I'd say leave it alone. But from what I've seen, from leveling them, I'm gonna bet your camber angles are closer to 0.8-/+ degrees. If this is the case, I would get the camber adjusted. The camber and caster kits are really the correct way to adjust camber/caster. You can move/adjust the arms without the kits, but its a PITA, and most shops will probably refuse to make camber/caster adjustments without the kits installed. So you will probably need to spend a couple hundred bucks to get the kit to adjust camber. It might seem expensive and its not a mod that your going to be able to enjoy, but its a lot cheaper then tires, and the kit should last the life of your truck.
If you get it all done, ask the shop for a print out of your before and after measurements, then bring them back here so I can look at them. If you don't mind.
I have the camber/caster bolt kit by SP installed and still have 1* negative camber with the camber bolts maxed out. What else can I do to get the camber down to around .2-.4? Upper control arm? Do they make camber bolts for control arm to give a little more camber/caster adjustment? 2012 raptor. Thanks! Great write up!
