Uplifter fuse issue
Haroldper23
I just installed 2 1.5 amp led lights to switch 3, the fuse was rated 10 amp, the fuse holds a second component and keep blowing on me, i tried 20 and 30 amp and it did the same, does any body knows how to prevent or fix this issue.
2018 2 Gen
H
Haroldper23
Lights are grounded, harnes its not shorting.
Im running 2 positives and 1 negative, the other is for switch 4 and its not giving me issues; bed custom lights.
The only thing i could think to do is to run a relay for the lights to separete the load of the second component.
NDO
You sound like you have a shorted LED. What brand of lights do you have and have you checked the resistance on them? One of my cheap Chinese LEDs failed with a dead short and was blowing the fuse on switch 2. Replaced the light and no more problems.
No way your fuse should be blowing with two 1.5A lights.
Sitdown
Suburbia, IL
Early on, I noticed my 17 upfitters to be much more finicky with fuses than on my Gen1. Easiest solution is to buy a relay panel to bump them all to 30a/35a. DIY solution, add relays to them all.
One option isn the LVJ panel, mounts right in the nook beside the battery and fender. More pics on their site, think i have some mounted images in my build
grumble
DFW
2018 2 Gen
Your fuses are blowing and doing exactly what they were meant to do.
There are 3 possible options:
  1. your wiring job is faulty and somewhere you have a wire shorted to ground. (most likely)
  2. your device is faulty and has an internal short.
  3. The upfitter relay box has a fault (least likely)
Should be fairly easy to troubleshoot by:
  1. validating that the device works properly when taking existing wiring and upfitter out of play. If bad, problem solved.
  2. checking every place where you installed wiring. It could be a bad/improper connection or the power wire could have the insulation scratched/cut/chafed and is shorting against the body
  3. If none of those resolve the issue, try connecting to a known-good upfitter switch.
93,180
56,460
khunter
