Upfitter switch ?
Discussion in 'Ford Raptor Problems and Questions Forum' started by Hawkeye, Aug 26, 2013.
  1. Hawkeye
    Hawkeye Full Access Member
    63
    168
    57
    Dec 24, 2012
    After working this weekend installing lights, I found that Aux. #3 (Purple)
    was dead. The light on switch comes on, but there is no power to the
    purple wire. I turned them all on just to see if perhaps purple was tied to
    another switch, but no luck. NO POWER to purple. Any thoughts???
  2. Hockster
    Hockster My 45ft Bluewater Party Supporting Member
    60
    5,144
    1,854
    Aug 9, 2010
    Winchester, Va
    Did you hook the wires inside the cab first? Sounds like you just hooked up the wires under the hood.
  3. The Car Stereo Company
    The Car Stereo Company aka nosbusa Supporting Vendor
    40
    24,779
    8,275
    Jul 8, 2012
    here, on frf
    fuse?
  4. Hawkeye
    63
    168
    57
    Dec 24, 2012
    I wired the lights - Whelen to #3, KC's to #4. #4, worked perfectly, #3 - no worky!
    Traced it back, checked the connections, checked the fuse, checked the purple wire - dead. Moved the Whelens to #2, they worked perfectly. Conclusion - #3 switch is not working. I saw a prior post with the same complaint - no solution so far. May have to call the dealer and note it in my file for a future fix.
  5. The Car Stereo Company
    40
    24,779
    8,275
    Jul 8, 2012
    here, on frf
    maybe lift up and check the aux switches from underneath the panel? being a 12volt guy, i probably would try to dive in and see what the problem is, but that me, i do this on a adaily basis. if it is a faulty switch definitely have it replaced.
  6. Hawkeye
    63
    168
    57
    Dec 24, 2012
    Hmm.....I suppose that I could change switch #3 for another one and see if the purple
    one is then live - that way I'll know it's the switch.
Share This Page
