6gun
Ok, this is bizzare.... just towed boat 1600 miles with no issue at all (except fuel burn...ugh). Truck and trailer lights worked perfectly. Disconnected boat to clean and shine... reconnected and no brake or turn lights. Lights on truck work fine. Running lights fine on truck/boat fine. Checked plug voltage with Flashers on, no voltage on R and L pin or round plugs when flashers are on. Ok, need to check connection on plug on the top of the spare tire as symptoms point to connection...however, before I dig into it, wondered if anyone else has had this issue and simple fix. Fuses check fine, but only found R and L turn fuses. Someone in an earlier post makes reference to a relay left in the glove box...?? More info on that requested. Thanks in advance.
