GEN 2 Rear seat uplatch inoperative
NHnewbie
The latch which holds the driver side rear seat bottom in the up position does not engage on my 2018 SCrew. Seat stays up but no need to pull the release lever to lower. Pax side works as expected. Haven't dug into it yet. This is the only squawk so far (first 500 miles).
kandewinn
Mine does the same, you have to push the seat up further (more force required) it will lock into place.
N
NHnewbie
"you have to push the seat up further (more force required) it will lock into place"
Thanks! Worked!
If you’ve stuffed a bunch of want to have stuff behind the seats, you’ll need to push even harder to get the seat to latch :)
