rear differential
H
HarleyGirl
FRF Lady
FRF Lady
Houston, Texas
Thanks. I installed a half spider rear differential cover & it's now leaking. Discovered at the dealership during a tire rotation. They are charging me for a rear flush with an extra quart charge of an additional $22. Feel like I'm getting nickel & dimed to death
Vash
OK, USA
The half spider is just a shield that offers a bit if protection and mounts over the factory diff cover using the same bolts. Only a replacement diff cover like the Mag-hytec or similar will increase fluid capacity.
If you didn't have leaks before the half spider install, I'm guessing you may not have used a good sealer applied to the bolt threads when threading the bolts for the spider/diff cover since the only place to leak would be around the bolt holes if the cover was never removed.
This is also a reason why I prefer an aftermarket cover that uses an attached o-ring rather than having to lay down a bead of sealant like Right Stuff or RTV. Although, you still have to apply sealant to the bolts regardless of what type of diff cover seal is present.
Yukon Joe
Russellville, AR
A flush will not cure the leaks. You need to add the dealer to the bolts add mentioned above.
Yes you are getting nicked and dimed. No reason for a flush and extra quart. What is there reason??
Yukon Joe
www.RUNRAPTORRUN.com
155mm
In my experience, no car dealers nickel and dime anyone to death. They only deal in the hundreds and thousands of dollars.
LONGISLANDRAPTOR
Long Island, NY
Yukon Joe
GREAT LAKES RAPTOR EXCURSIONS
im not sure about the extra quart but the reason for the flush, is that the diff cover comes off to re seal the cover.
when the diff cover comes off the fluid comes out. No tech in the world will offer to replace the old fluid back in.
J DAMAGE
NJ
There gonna have to remove the cover, and clean the surface, to reseal and stop the leak,as stated by LONGISLANDRAPTOR, What I don't understand is the cover is sealed on there so dame well, how the hell did it start leaking, just from removing a couple bolts, I had to pry like hell just to get mine off for my cover change, wonder is it the stock cover she added the spider to, or was the cover changed and the spider added down the road, then that would be the case of not sealed good.
Members online
93,202
56,485
bjorn-dpc
