Popping sound
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by vamsye, Feb 12, 2020.
  1. vamsye
    vamsye Member
    46
    11
    Apr 23, 2013
    New 2019 raptor here.
    Today When I was driving i heard 2-3 times a popping sound from truck. This is the first time i heard it. 4000 miles on truck as of now, not sure what that sound is.
    Edit:
    I was driving the truck and I hear a loud popping sound from under the truck, it was like empty can blown kinda sound. The first time was louder and this happened when i let go off the gas to step at the red light.
    the same thing happened two more times but these two times the sound was not that loud.
    i feel like the sound came from under the rear side of the truck.
    Sorry did not post more details earlier.
    Appreciate ur feedback.
    Thanks,
    —Vamye
  2. hj_s14
    hj_s14 Full Access Member
    209
    115
    Oct 8, 2019
    CA
    Man , you gotta give more info than that... I’m not sure if anyone would be able to help with “pop” noise ...
  3. jabroni619
    jabroni619 FRF Addict
    1,863
    1,189
    Jun 13, 2017
    Agree with above, way to insufficient information to even begin offering suggestions on what it may be.
  4. vamsye
    vamsye Member
    46
    11
    Apr 23, 2013
    I have updated the original post, thanks!
  5. dirtyboot
    dirtyboot Member
    19
    7
    Jan 24, 2020
    mountains
    Like a rear-end differential clunk when you go from the throttle to the brakes for a light?
    I was just looking to create a thread about this question - as I've payed more attention to it over the past couple days it's transitioned from originally seeming like something was sliding around in the bed, to a diff clunk, to being rear-ended, to a decel pop, but haven't tracked down the source yet. 5100 miles, guess I first noticed it around 2-3k but had been dismissing it as expected diff noise.
  6. vamsye
    vamsye Member
    46
    11
    Apr 23, 2013
    Yes, you are right at first I thought there was something sliding around the bed of the truck.
  7. Raptorrunner2019
    Raptorrunner2019 Full Access Member
    239
    124
    Mar 23, 2019
    Wewahitchka
    I had gear pinion out on mine almost new. It was only at a certain speed 45-55mph. And with a certain amount of throttle (light), like what it takes to maintain speed and a little more. If you hammer it didn’t do it and didn’t do it at no throttle. Got to be really annoying. Good luck on fix. Sounds like you might want to have it looked at, but make sure it is repeatable.
  8. vamsye
    vamsye Member
    46
    11
    Apr 23, 2013
    Thanks, I will make a note of "gear pinion". Today when I was driving I did not hear the sound. I need to hear it again and try to record it before going to the dealership.
  9. Ktl302
    Ktl302 Member
    May 6, 2019
    Oklahoma
    Agree that it's probably a full of fuel pop...
    sixshooter_45 and vamsye like this.
  10. vamsye
    vamsye Member
    46
    11
    Apr 23, 2013
    Yes, it was like 2 minutes after filling up gas.
    What is a fuel pop?
    Should I get this checked?
Share This Page
