John Butler
how do you load pandora in my 2019 Raptor? Thanks
Is the cubby the 2 USB ports under radio in front of shifter?Do you have it plugged into you USB in the cubby? Plug it in and launch the app on your phone. It should pull up then. Also, there are like 3 different ways to view it.
This is the vid Ford produces on how to set up Apple Car Play.
Ok thx I have android and it works 50% of the time and apps wont load on sync as a source which it did on my gt350Yes.
Sent from my SM-G965U using Tapatalk
I do. Just watched video says need to have factory I use a aftermarket cable maybe that's the issue will hook it up with cable came from phone see it that helps.I don’t use android however saw this. Do you have Android auto app downloaded?
