Out with the Ram in With the Raptor
Mxsledder
Utah
I bought a 19 Ram 3500 HO Limited Cummins for use in my business and just never quite loved the truck. I made the mistake of getting the factory air bags and for some reason it just rode terrible. The Asin transmission was very slow and annoying through the first three gears. I never even ended up towing with the truck as I use my semi trucks for that so I decided to try a half ton and take a break from diesels.
Just got a deal I liked and pulled the trigger on a 20 Raptor. Only 50 miles on it so far but I’m already liking it. Very excited to get a few more miles on it. The steering is surprisingly stiff even coming from a 1 ton truck but other than that I like about everything so far.
I will say the interior is a pretty big downgrade coming from my Ram Limited but that’s the one sacrifice I had to make.
JohnC12
Leesburg, VA
Congrats on your new truck and welcome to FRF. With regards to your stiff steering, have you tried changing your Selectable Steering options? I drove my Raptor for the first few days and didn’t even realize the truck had this option.
Welcome to FRF!
Get some recreational miles on the truck, and the dated interior will fade away quickly.
M
Mxsledder
Utah
Thanks guys! It is in normal mode ride now, I will try comfort out and see how much that helps.
I did make it through a fairly tight drive through without too much trouble so that’s a big relief.
Denvertaco07
Denver, CO
i think the cold pressure is 38, check inside drivers door. There are a lot of opinions, some do like 38 front, 36 rear. But anything but what most dealers have it at (leaves factory high i think) which is 10 to 12 too high.
df4801
Agree. Much better ride at 37-38
Russ103
MD
What should I set the pressure at?
Im at 32 front and 30 rear. Definitely a softer ride. Although I like the steering in sport.
BTW, Ford lets you disable the seat belt **** alarm. Not sure if Dodge did. But I always disable mine.
Congrats on the new truck!
93,319
56,605
Randigitty
