Oil plug replacement
TriGui
SC
didn't even know it was plastic. ill be swapping mine out in the future for sure.
wheelman55
Big Bend or MN
I put this one in my 2018 Raptor to replace the plastic OE version:
aandrews109
Florida Panhandle
What year is your truck and do you have a plastic or metal Oil Pan. Running a Fumoto Valve on my '19 with metal pan. Makes changes very easy with no mess!
F
FMoon83
Porter, TX
It’s a 17 with a plastic pan. Just trying to see if it’s worth the $80 or just stick with the originals.
wheelman55
Big Bend or MN
FMoon. It’s only worth it if you are going to be changing your own oil.
PS. If you have the dealer change your oil, make sure to crawl under your truck to see if they put all of the fasteners back in the access cover. Also check to see if they cleaned up the oil mess.
