NEW PRODUCT ALERT! * HPA Air Systems by KSI Engineering *
HAYNES OFFROAD
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
I don't see anything protecting the valve (or top), like you see with C02 tanks. What would happen if the top breaks (looks longer than average). Will it become a flying missile? Or is there safety measures with this design to prevent that?
Ok so talking with the manufacturer I now have more detailed info about this.
So obviously with ANY pressurized cylinder, it should be handled with extreme caution no matter the gas contained within it (CO2 or Air).
With that said,
The joint between the tank and the valve is very robust. This is the same thread design used on firefighter tanks in Europe & Asia (US firefighters are slowly moving to this thread design as well) and they have these strapped to their backs. It is equipped with a ASTM safety groove to vent the air in the event that the valve is removed with air still in the tank or if the regulator breaks off of the tank. In other words, your safe even with a catastrophic failure.
The regulator can be unscrewed and removed from the tank valve. This reduces the height of the system, allows the regulator to stay warm in the cab of the truck while the tank is in the bed, and helps to prevent system damage. Please see the picture of the system with the regulator removed. Being that it only takes a few seconds to remove the regulator, we recommend keeping it off while the tank is not needed and keep it with the rest of your air supply gear.
dkfc13
HPA Systems LLC.
SE Michigan
Since this can do both shock inflation and tire inflation, it looks like I might have a Powertank N2 shock inflator kit for sale :)
93,180
56,460
khunter
