New 2024 R issues with key and drive modes after ppf install
EagleFive
EagleFive
Florida
I went ahead and charged the battery fully. No change. Key works fine to open doors. The car even wakes up as I get close to it. But it won’t unlock the doors automatically. Also from time to time the car give me a “no key detected” error but I can drive fine. I’m thinking the ppf messed up some sensors? What else could it be? Both of my keys do same thing. Both are new.
OBXRAPTOR17
Did u remove negative terminal for 15 minutes after charging? This will reset BMC. If you attached alligators to positive and negative terminal the BMC will not see the charge. Negative alligator clip has to go upstream from BMC on the metal flange . Otherwise disconnect negative terminal for 15 min. If that doesn’t work time for a visit to dealer.
EagleFive
EagleFive
Florida
I don’t have that. Just the charger I bought. Are you saying to disconnect the battery?
OBXRAPTOR17
As long as you keep positive connected it won’t affect anything . It will be the first thing your dealer does.
