Need Transmission Wiring Harness
panda
Fort Worth, TX
Hey guys - I smashed a wiring harness over the weekend and can't seem to find a replacement part. I still might try to repair this one, but I was hoping someone could help me identify the part number for this piece. Also it would be great if someone happens to have one from a blown motor or totaled truck.
I believe it's the harness that goes from the PCM to the Transmission, the only identifiable number I've seen on the truck is AL3V 15525 S081N
Here's a picture:
Any help would be appreciated, I've had no luck on Ford Parts Sites.
panda
panda
Fort Worth, TX
Thanks IceCobra - I think you've found it.
The section highlighted here is what's damaged:
It looks like you have to buy the entire harness, Part Number 12A581. I'll work on fixing the one I broke unless someone has one they want to get rid of cheaply!
Again, I appreciate it - I spent a couple hours searching, should have came here first!
panda
panda
Fort Worth, TX
Checked out the one I have and maybe it isn't damaged afterall. Truck still in limp mode so back to the tech it goes...
