GEN 2 My First Truck, 2017 Ford Raptor Supercrew
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by image98, Sep 18, 2017.
  1. image98
    image98 Member
    42
    37
    Sep 18, 2017
    California
    Forscan
    Hi, I learned about Forscan on this forum. if you search, there are a couple of threads that will walk you through the entire process. I purchased an USB OBD interface from amazon for $30 bucks and ran the Forscan PC software on my PC.
    Forscan thread
    http://www.fordraptorforum.com/f260/forscan-changes-tweak-your-truck-52149/
    USB Device
    https://www.amazon.com/gp/product/B01F0GVBWY/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    Bluetooth Device
    https://www.amazon.com/gp/product/B006NZTZLQ/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    ---------- Post added at 12:25 PM ---------- Previous post was at 12:21 PM ----------
    I used about three liters (three bottles), but with this being my first application of the product, I wasted a fair amount on test surfaces like plywood and cardboard. I also applied three heavy coats, so two liters certainly could be adequate.
  2. carholic
    carholic Member
    30
    8
    Jan 15, 2017
    Thanks. Don't own a PC. I wonder if there is anyone that will do it for a charge. Better than me going out buying a PC.
  3. Raven13
    Raven13 FRF Addict
    2,196
    3,001
    Sep 30, 2014
    College Station, TX
    Howdy and congrats
  4. image98
    image98 Member
    42
    37
    Sep 18, 2017
    California
    Forscan for PC
    If you have a Mac, you can also run Forscan with Windows via BootCamp.
  5. image98
    image98 Member
    42
    37
    Sep 18, 2017
    California
    Rear Sway Bar Performance
    Hi, I contacted Hellwig directly and they gave me that part number for the Raptor. Yes, it's the same kit for the standard F-150. The end links are adjustable. The U-Bolts are not 100 percent centered, but otherwise everything bolted in seamlessly. Street cornering and handling has improved tremendously. Prior to the install, I could feel the bed tilting through corners, but now its perfectly level and the trucks feels more balanced. I really wish Ford had included a rear sway bar as stock equipment, but with an electronic disconnect.
  6. Heelfan1
    Heelfan1 Full Access Member
    47
    95
    30
    Sep 3, 2017
    Western NC
    I ran one of these on my 2011 Harley edition and really like it. Of course this was a different animal but cornering was greatly improved, always thought they should have installed one from the factory.
  7. ReyLorenzo
    ReyLorenzo Full Access Member
    211
    155
    Jun 25, 2014
    Lake Mary, FL
    Looks great! Quick question about the UPR catch can install. I bought one for my 2018 and I was almost done with the install until I couldn't remove the intake pipe in order to drill and install the WOT hose. Did you have hard time taking that pipe off? I losened the clamps on both ends and I can't pull the damn thing off. Seems like it's secured to something somewhere else.
  8. image98
    image98 Member
    42
    37
    Sep 18, 2017
    California
    Removing the Intake Tube for UPR Catch Can
    Thanks. Yes, it was a tight squeeze removing the intake pipe as it's squeezed between the turbo intake pipe and a pad fastened to the right hand wheel well. I do think there are minor differences between the 2017 and 2018 Raptor intake. There were no additional fasteners holding my intake in place.
  9. image98
    image98 Member
    42
    37
    Sep 18, 2017
    California
    Wiring Upfitter Switches
    I plan on installing LED lights and a light bar so I decided it was best to prep the upfitter switches and wiring. I wanted to go with a quick disconnect and waterproof type connection. After some research, I settled on the Deutsch 2-pin connector housings and created my own 14 gauge ground wires.
    [​IMG]
    The stock upfitter wires are short.
    [​IMG]
    [​IMG]
    My ground wires assembled. I ran them all to the left bolt of the ECU.
    [​IMG]
    I don’t have to worry about anything shorting out and I can quickly rearrange my devices without rewiring.
  10. murph145
    murph145 Full Access Member
    40
    372
    112
    Sep 7, 2017
    Simi Valley, CA
    Nice I think I need your help lol you seem pretty handy.
    Ordered a Rigid 40" midnight curved light bar for the front bumper and some of their midnight cubes for the fog pockets.
    Where ats do you live? I am in Simi Valley. I am good with mounting etc but I have no clue about wiring etc and don't really want to pay a shop to do it.
    Good job!
Share This Page
