KHC Standard Length LCAs
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by rayofsi, Oct 24, 2020.
  1. rayofsi
    rayofsi FRF Supporting Member Supporting Member
    248
    105
    May 6, 2019
    NYC
  2. DEGBTI
    DEGBTI Full Access Member
    55
    229
    102
    Feb 21, 2018
    San Diego
    cant use stock shocks, deal breaker. RPG make the same LCA, but you can use your stock shocks or aftermarket. And cheaper!
  3. PorterW1111
    PorterW1111 Full Access Member
    832
    795
    Apr 19, 2020
    Florida
    Yeah looks like a great kit but does seems pricey...camburg lowers are $2k
  4. RDFTS
    RDFTS aka Rick Supporting Member
    13,646
    10,808
    Nov 10, 2013
    Southwest Missouri
    Typically when you want to replace your LCA with something like this is because you want to run dual shocks. And if you are doing that then not sure why you would settle for the non-adjustable stock shocks. You are going to upgrade your shock and take advantage of the full functionality of the kit. So it makes sense why this wasn’t designed for stock.
    I thought KHC was making their own UCA but looks like they dropped it
    But to me, if you are going to do all that, might as well jump up to the mid-travel kit.
    https://krazyhousecustoms.com/khc-off-road-fabricated-mid-travel-lca-kit/
  5. rayofsi
    248
    105
    May 6, 2019
    NYC
    i have a overbuilt mall crawler. Already have aftermarket shocks, and ucas, didn't want anything wider since i run 0mm wheels.
    mid travel brings up the cost significantly
    i should have gone mid travel first time around hah.
Share This Page
