jjjaymmman
- Joined
- Feb 2, 2011
- Posts
- 8
- Reaction score
- 3
If it is only 150 Watts (and hopefully has an acceptable wave form), use is mainly restricted to computers and A/V equipment. This means that when i replace it with a 230 VAC unit with more wattage, I also have to check and probably replace the 12 Volt DC cabling.
What are you planning on hooking up that **MUST** use 240VAC? Many components have the ability to support both 240 and 110. Just curious, when I lived in germany (220 VAC) i purchased a PS2 and swapped the power board out with a 110. Also all your devices will convert the AC into DC internally for the component to run.
