fshol
The Crew I ordered comes with the 110 V power inverter. Since we have 230 V over here, I want to replace it with a 230 V unit. Does anyone know where the unit is located?
Under the center console is correct. Should be plenty of room to change to another unit. I believe the factory unit is rated at 400watts. 230v won't add any additional heat.
Thanks, so i will have to find a way to get under the center console. Anyone with experience how to get there?
FYI, the inverter socket in my truck (120v) indicates 150 watts.
Wow, that is a little one. Toyota is using 400watt inverters. Was hoping Ford's would be at least the same. 125watts isn't going to power much.
