GEN 1 Hp tuners and 2010 6.2
jokerz
Is the pcm code the same for the 2011 as it is for the 2010 if so greatly appreciated if someone knew this answer.
MTF
Celebration, Florida
No, the 2010 1/2 6.2L Raptor has a different PCM and PCM software than all the 2011-2014 Raptors
MTF
Not really, because the 2011-2014 have a select shift setup, and other changes like the info screen behind the steering wheel.
The BCM module is also different which the PCM monitors.
Have you look at all the HP forum threads, as far as I remember going through them two years ago nobody was able to get a working Tune file for the Raptor to start editing. But I haven't been there in two years so knows.
2010 1/2, I doubt will ever be available, just not enough of us around to warrant spending money.
jokerz
jokerz
Sct it is then
