Hey Everybody,
So I used the easy method to make the following changes
disabled doubLe honk on exit
enabLED bambi mode
front fog with high beam
the first 3 work without any issue:
The daytime running Light and parking lamp changes are workiing except I do not have daytime running lamps ...only my parking lamps are on when in drive/gear ---please note that the headlight switch is is auto mde the entire time.
If someone knows how to use easy method to have
daytime running lights on
with parking lamps and fog lamps on , pLease LEt me know...
If i need to undo my easy changes to use coding methos...so be it...
cheers
enabLED bambi mode
cheers
