DEAD BATTERY and TRANSMISSION, AUTO START*WARNING*
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by WowTechnologies, Mar 27, 2014.
  1. WowTechnologies
    WowTechnologies Member
    17
    5
    Mar 15, 2014
    Lafayette, LA
    Guys & Gals…had a dead battery this morning because I left the running lights on overnight while my New 2014 SE Black Raptor was parked in a closed garage (I know..duh). The battery was completely dead and when I went to start the truck nothing as is normal with a completely dead battery. I pulled out a battery charger that I have used many times before and it would not work on the truck battery and showed a fault. The fault indicated that the connected battery had a voltage that was “too low” to accept a charge. I have used this charger before and knew that I could let it run for a few seconds, fault out then repeat several times to get the battery back where it would accept a charge. It worked and I was able to start the truck. I disconnected the charger, closed the hood and got into the running vehicle. I put the Raptor into reverse and the truck lurched backwards unlike the normal and slow reverse speed I am used to. I backed out the driveway and put the vehicle into drive and nothing happened. I put the vehicle into park and back to drive and gave it a little more gas and started moving but the truck felt weird. I discovered that my truck was transmission locked into 5th gear and would not move. I tried manual shifting while in drive, manual shifting while in manual. I stopped, started but truck would not unlock from 5th gear. When I tried the manual approach, the 5th gear light would flash and go back to solid. I drove in 5th gear the whole way to my office, about 11 miles to let the battery charge so I could try and restart. I then shut down the truck, restarted several times, took out key, repeat to make sure I had reset any electrical issues and drove the truck around. This worked and the truck transmission returned to normal. I drove the truck on a sales call with everything working normal (About 30 miles) and parked. When I returned to the truck and tried auto start, the truck acted like the battery was dead again. I got in the truck expecting a dead battery but the truck cranked like normal. I drove back to office, stopped truck, tried auto start, started working again and has been since. WTF? I know the modern vehicles are tied into the electrical system but WTF? Good news, I got LIVE TV playing on my nav screen today! (Another Thread)
  2. Harblar
    Harblar Full Access Member
    459
    368
    Oct 28, 2012
    Aberdeen, SD
    I had this same exact issue about a month ago. My truck had been sitting outside at the airport for a week and a half while I was gone in a trip. Came back and the POS aftermarket security alarm I have had drained the battery to nothing.... In a week and a half! Anyway, finally got it charged enough to crank and then let it sit running for half an hour. When I got in and started the drive home I noticed something didn't seem quite right. Sounded wrong at low speeds and didn't want to accelerate like normal. Pop up the gear indicator (since that always hides itself after a dead battery) and sure as hell stuck in 5th. Got home (only 5 mile drive) and tried putting it into reverse and noticed a lurch/clunk. Turned it off and back on. Still stuck in 5th and lurching when shifting into reverse. Was slightly concerned, but figured the tranny must be partially frozen up since it'd been sitting in -10 degree weather for over a week. Let it sit in the heated garage over night and the next morning everything worked normal. Never occurred to me that it was an electrical issue all along.
  3. WowTechnologies
    17
    5
    Mar 15, 2014
    Lafayette, LA
    I knew somebody else had experienced this. There are postings on the web with other owners having this problem. Apparently there is a TSB for this that was released in 8/13 to fix this. Google "dead battery ford f150 locked in 5th gear"
Share This Page
