Deleted member 12951
Guest
Yep, I knew that was exactly what the tech did. Seen it happen.Ok update.
good news: got to the shop before they broke out the grinder. Explained to them that there are a lot of other adjustments and I can take the truck and do those myself. Because they didn’t do any of the services got out with no charge.
the bad: turns out the tech didn’t loosen the rack side lock nut. Then cranked on the tie rod so hard that he actually started unscrewing the Clevis from the rack. That’s A LOT or torquing.
just ordered the RPG lca mount doubler/trippler and will order the locking cams too.
We sell the locking CAM’s. There are two, you want the HD one. It is actually torque to 198 not 258
