custom Center Caps for FUEL wheels?
Bullishone
Anyone know of a place that can make custom SVT or Raptor center caps for FUEL wheels?
Quartz
Denver, CO
Bringing this thread back from the dead. Does anyone have info regarding replacement center caps for fuel wheels?
FP Forged
Justin
Reno, NV
Right on, I have the 17" Fuel Hostages in matte black. Is it possible to make a set for these rims?
Hostage - D531 - Fuel Off-Road Wheels
Yep, it would be a flat style like the method roost caps I make. I did one set for another member for his Mickey Thompson wheels. I would need you to send me a cap so I could get a template for the machinist. They would be about 3mm thick and bolt on with the existing fuel bolts.
Quartz
Denver, CO
The thing about the hostages is the center caps cover the lugs. I want a cap just like the roost you posted. I'll post a pic of the rims with the caps off later today, but regardless I'll send a cap to see what you can put together.
FP Forged
Justin
Reno, NV
I can have it done but it might look strange. The hostage has two bolt patterns in it. 6x135/6x5.5 and with 6x5.5 being bigger than 6x135 the cap would extend past the 6x135 holes. And depending on where the bolt holes for the cap screws end up it could be a mess. I'm willing to take a stab at it though
Do the studs or lugs protrude from the face of the wheel when you don't have the cap on?
Quartz
Denver, CO
Definitely, I can see it being a mess. The lugs do protrude and there are two mounting screws perpendicular from each other for the cap on the face of the rim as you can see in the pics. What do you think, a mess right?
FP Forged
Justin
Reno, NV
Yeah, it wouldn't look quite right. And you would need to run open ended lugs (shorter) to clear the cap. But based on the surface not being flat, we would have to replicate the shape of the stock cap. I'll see if the plastic company next door has a piece of plastic I can try to make a template out of to see if fits.
Quartz
Denver, CO
It's worth a shot if you have an idea that gives it a more "flush" look and strength compared to the plastic. I don't mind sending a cap over to you if it makes it easier. Almost digging the way it looks without the caps and rocking the rusted hubs. Been reading a couple different forums of people looking for hostage center cap alternatives but there's nothing.
