Caliper bolt TQ specs?
Front caliper pin bolts: 27 lb-ft
Front anchor plate (bracket) bolts: 184 lb-ft
Rear caliper pin bolts: 26 lb-ft
Rear anchor plate (bracket) bolts: 181 lb-ft (M16 bolts) or 258 lb-ft (M18 bolts)
Note that the truck needs to be put into brake service mode before any disassembly or repairs are made to the front or rear brakes.
Monte87
Monte87
NY ******
Thanks for your reply! Fordtechone. Appreciate it!
Anthony
Monte87
Monte87
NY ******
Hi-
What is the proper procedure for BRAKE MAINTENANCE via Gen3's? It seems there are lots of confusing vids on youtube and not much on here. Can ya help me out, please.
Thanks Anthony
Hi-
Thanks Anthony
Monte87
Monte87
NY ******
Thank you very much.
Question, can you start at #4 in activatiin procedure if you don't have E-brake on?
Thabks Anthony
