CAI problems
sellerc
Installed the Whipple CAI tonight and now my truck is throwing an engine coolant temperature code (PO116). Any ideas what it takes to fix this?
Wizo
Orlando
Did you install the sensor into the intake correctly or did it somehow get unhooked?
pjones
Thats a weird code to throw, since cai doesnt touch the cooling system.
khcdave
South Brunswick NJ
make sure the air temp sensor is pushed all the way in. It may seem like it but sometimes its not blocking are flow to it. Mine started throwing codes also.
S
sellerc
CAI
Double and triple checked the sensor and couldn't get it to go in any further, looks like a good seal. Put the OEM intake back on last night late and truck is fine this morning.... no idea what the problem could be.
khcdave
South Brunswick NJ
These trucks are so damn sensitive. Clear the cam (disconnect the battery) and drive it hard. You could try reinstalling at same time. They are so adaptive now its redic. They sense every little change. I logged mine, checked factory tune and my torque table are set very low so any piggy back modules set my wrench light off. Tune is the only way I can go.
pjones
Can someone educate me on ait sensor causing coolant temp codes? If ait is disconnected or the signal is off, why would it throw Ct code?
MadRaptor65
When Whipple installed my CAI it poped a few codes. I took it to Whipple and they had fixed in no time.
Your best bet is to call them (559) 442 - 1261 and they should be able to walk you through it.
Good luck!
93,278
56,567
erikn
