BuiltRight Center Dash Mount
OffroadAlliance.com
Boston, MA
BuiltRight Industries has done it again with another great accessory for your Raptor! If you're looking to mount a cell phone, GPS, dash cam, radar detector or other accessories, look no further than the new dash mount specifically built for the 2015+ F150 / 2017+ Raptor.
Features:
  • Mount your cell phone, GPS, dash cam and other accessories with ease!
  • Laser cut and CNC formed for perfect fit
  • Durable black textured powder coat
  • Made in the USA
  • Patent Pending
Order Link ---->>> Link to ORDER ----->>>> FORDRAPTORLIGHTS
The BuiltRight Industries Dash Mount provides a rigid, durable mounting point for all types of accessories. With room for multiple mounts, users can attach and configure their devices with infinite adjustability. A popular combination with our product testers was cell phone, radar detector and dash cam, from left to right. The Dash Mount was born from the lack of phone mounts that give you the ability to position your device where you want. 'RAM' brand ball and socket mounts are an excellent addition to the Dash Mount and although we don't yet have them in stock, they are readily available on Amazon. The slots used in the design are sized to accommodate AMPS standard attachments.
Installation is very straight forward. The laser cut and CNC formed bracket attaches to the tray located above the dash using four machine screws, included in the hardware kit. The four .25" holes used must be drilled by the user in the OEM tray. Should you choose to return to stock, the OEM rubber mat inside the tray conceals the holes.
The bracket is manufactured from 12ga mild steel and finished with a durable black texture powdercoat - a very close match to the OEM dash finish. Each kit contains the Dash mount bracket, four machine screws, four washers and four locking nylon nuts. Also included are printed instructions and a BuiltRight sticker!
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
How do you get the bottom bolts on? Does that plastic piece just pop out?
Yes, first you remove the speaker cover. Then a few screws under the speaker cover and then the tray pops out. This kit comes with installation instructions and a installation video will be out in the next few days.
Robtor310
Redondo Beach CA
I like it and am thinking about pulling the trigger but $45 for the part (which im ok with) but $33 for ground shipping?
How about free shipping... :biggrin:
Gunner11
Do those ram mounts work well with heavy off-roading?
Loufish
Burbank CA
Looks nice....I like the fact it can mount pretty much whatever you like with all the slots...When I see the install vid then I can see how it's attached as my only worry is will it hold a Lowerance GPS and hold up to desert running.....Id like to do some Raptor runs but it seems all the organizers use Lowerance as their GPS of choice which means their route/mapping will be exclusive to Lowerance.
Yes..very interested, thanks
