GEN 2 BBK 73mm Throttle Body
nikhsub1
Los Angeles
I have one, I installed it when I installed my AMS intake tubes so I can't give you a real good assessment of the TB by itself. I am having a CEL though, leak detected between the TB and the intake valves... The thing is tight so IDK.
Kirby Lastinger
Kirby Lastinger
Lakeland, FL
Thanks for the info. It doesn’t have any connections other than their plug correct?
WHYUMAD
New Orleans, LA
I’ve always had random issues with aftermarket throttle bodies. Your best bet is a ported stock throttle body if anything.
Kirby Lastinger
Kirby Lastinger
Lakeland, FL
I have a Ford Performance on my GT500 and never had an issue with it.
Thanks for the input.
nikhsub1
Los Angeles
The BBK is a solid unit, well built I think it uses OEM electronics. The TB on the raptor was SOOO tight when unscrewing the 4 bolts. It could be that I just don't have it tight enough. I'm gonna tighten it a bit more tomorrow morning. FWIW, the code doesn't pop up all the time, it's random so that lends weight to what WHYUMAD is saying...
