Axel spring perch not Flat?
Gumby
Nashville
Ok between rain drops I got the axel bolts out. The spring perch is not Flat as I expected. Should it be Flat is the Question? This is a 2014 Roush I believe the previous owners did a lot of spinning the tires. The perch is really rounded letting the axel "rap" or roll forward and back. The pic is of a straight edge sitting on the perch. if is should be flat I am open to suggested fit. When the rain lets up I will try to get better pics.
Gumby
Gumby
Nashville
other pics
New recaros
Colorado
That’s correct, if it were flat, you would snap that spring right at the edge. They are spreading out the load.
Gumby
Gumby
Nashville
@New recaros your response doesn't make any sense to me. The block between the housing perch and the spring is flat where it touches the spring.
There is Obviously a lot of movement in the past the holes in the perch are really wallowed out. there shouldn't be movement.
New recaros
Colorado
I thought on all the roush and lifted trucks using springs to lift them, they removed the block and the leaf pack sat on there. I must be wrong if you have a block between
Gumby
Gumby
Nashville
So this was my fix. I took 3/16 steel plate made 2 new pieces to weld on to the axel housing perch. Welded them all the way around. I had to fill the ends... This worked out good.
The holes were so badly worn.
I just got back from test drive. It drove nice and straight. The roads were still wet... so no launching (from 40 MPH) but feels way better. I think it is fixed. Thanks to all who responded to this and my other thread.
Now if I go with another set of springs I will have something flat to bolt them to.
93,180
56,460
khunter
