Audio and Surround Sound Settings question?
BangBang
It’s ticking me off and I can’t find any help in the manual.
But, with Bluetooth and using my iPhone playlists the audio and surround sound setting keep returning to the programmed settings..
I want them to stay at what I want them at and not what Ford set them.
Anyone know how to keep them set and saved?
lawdog
Not sure what you mean...my head unit settings for EQ, surround, etc., stay the same no matter what source is used on my 802a. On my old Tundra, you could set them differently for each input and it would stay that way, which I liked better. I don't use Bluetooth that often, but I don't recall it changing the settings when I did.
BangBang
BangBang
I use Bluetooth connection.
Play music via playlists.
Turn on the truck and everything connects.
Select phone under sources and the tunes play.
While in audio I go down click the setting button.
The eq comes up.
I adjust it to my liking and select surround sound.
Drive to where I'm going. Get out and do my stuff.
Get back in the truck and start down the rode and the tunes sound wrong.
Pull up audio, go to settings AND the eq has gone back to the factory middle settings and to stereo. Undoing my setup.
It does it constantly.
Quaesta
The eq comes up.
Sounds like you have an issue mine stays where I set it.
