Another Douchenozzle Article: "5 Ways the Chevy Colorado is Better Than Ford Raptor"
WhatExit?
48th state
There can only be one king. One high exalted mystic ruler. One Grand Poobah. And in the world of off-road-ready factory-special pickups, that’s the 2017 Ford F-150 Raptor.
The full-size turbocharged Raptor has the most power, the most gears, the most wheel travel, the most ground clearance and the biggest tires in its class. What’s more, it just looks bad ass. It’s the truck to drive at 100 mph through 100 miles of desert.
But there’s a new challenger in town: a worthy competitor called the 2017 Chevrolet Colorado ZR2. The engineers at General Motor’s Chevy division didn’t just throw a lift and some 31-inch tires on a Colorado and then go out for fro-yo. They did it right, adding wider tracks, longer suspension travel and an impressive shock package. They also modified the body for additional ground clearance, proper skid plates and sheet metal protection.
The results are impressive. In fact, the Colorado ZR2 is so good that after some time in each, both on and off –road, we’ve been able to identify five ways it’s better than the rajah Raptor.
The ZR2 Is Smaller
When it comes to trucks, smaller is rarely perceived as better. But if you’ve done any serious off-roading, then you know size isn’t always your friend out on the trail. The full-size Ford Raptor is quite a bit bigger than the mid-size Chevy Colorado ZR2.
A quick look at the dimensions tells the tale. The big, bad Raptor is 2.4 inches wider and 6.3 inches taller than the ZR2. It’s also up to 31 inches longer. At 5,700 pounds, it outweighs the little Chevy by at least 700 pounds.
When off road, that means the lighter Colorado can run where the bigger Raptor cannot. In city driving, the ZR2 is easier to park, easier to live with and fits in all parking structures – which the Raptor does not.
The ZR2 Has a Diesel Option
If you want the most power, buy the Raptor. Its 3.5-liter twin-turbocharged Ecoboost V6 engine puts out 450 horsepower and 510 pound-feet of torque. The ZR2 comes standard with the same naturally aspirated 3.6-liter V6 engine in the Camaro sports car, rated at 308 horsepower and 275 pound-feet of torque.
But what if you want a diesel? Check the option sheet and you’ll see the ZR2 is also available with a 2.8-liter Duramax diesel engine. The turbocharged four-cylinder is rated at 186 horsepower and 369 pound-feet of torque.
It costs an additional $3,500, but the fuel economy benefit is material. And with the diesel’s low-end grunt – max torque comes at just 2,000 rpm – the ZR2 climbs grades like a tractor.
The ZR2 Gets Better Fuel Economy
Even with its standard V6 and 8-speed automatic transmission, the smaller, lighter ZR2 stretches a gallon of gas farther than the Raptor. The Environmental Protection Agency rates the Chevy at 16 mpg for city driving and 18 mpg on the highway.
Not surprisingly, the ZR2’s diesel really pulls away from the Ford’s V6 in this department. Despite its 6-speed automatic transmission, the ZR2 with the Duramax is rated at 19 mpg city and 22 mpg highway. And in recent real-world testing, we averaged 22 mpg in 300 miles of mixed driving, which included several hours off-road.
The EPA rates the turbocharged Raptor, which has a 10-speed automatic transmission, at 15 mpg city and 18 mpg highway. That’s impressive for a truck of this size and power. But to come anywhere close to its fuel mileage ratings, you have to stay out of the boost. It’s easy to find complaints on the Raptor forums about the truck’s thirst.
The Raptor also drinks premium fuel. The Chevy’s V6 lives on cheaper regular grade.
The ZR2 has a Locking Front Differential
There’s only one pickup truck in this conversation that has a standard locking front differential, and it’s not the Raptor. Ford equips the Raptor with an electronically locked rear differential and you can pay an extra $500 for the optional Torsen limited-slip front differential.
The ZR2 is the only mid-size truck with front and rear electronically locked differentials. Both are standard. The only other truck with this feature is the mammoth Ram 2500 Power Wagon.
Front and rear lockers might not sound like a big deal, but off-road enthusiasts will tell you that being able to lock that differential and send power to both front wheels will get you out of many undesirable situations.
The ZR2 Costs Less
The ZR2 package sits above the Z71 trim level on the mid-size Colorado pickup. Chevy offers the ZR2 in two configurations: Extended Cab with a 6-foot bed; and the Crew Cab with four full-size doors and a 5-foot bed.
For the Extended Cab, prices start at $40,995, including $995 for destination. The Crew Cab starts at $42,620. That’s about $5,000 more than the Colorado Z71, but if you plan to take the truck off-road, it’s worth it.
It’s also a steal compared with the Raptor. A base SuperCab Raptor costs $52,375, including $1,295 for destination. That’s $11,000 more than the base ZR2. Jump to the SuperCrew and you’re looking at $54,065. Load it up with options and the Raptor can surpass $70,000.
Check all the option boxes on the ZR2, including the diesel, the style bar and the cool-looking bed-mounted spare tire carrier, and you’ll touch $50,000. Not a bad deal for such a capable truck, especially one that can steal this much thunder from the king of the off-road pickups.
https://www.trucks.com/2017/09/01/chevrolet-colorado-zr2-better-ford-raptor/
---------- Post added at 08:34 PM ---------- Previous post was at 08:32 PM ----------
So the Raptor is "the king of the off-road pickups" but the ZR2 is better but only in 5 ways?
jabroni619
I think the article has some fair points.
The smaller size certainly would make it easier to live with for most people, especially parking or going on tighter trails. But it's also a disadvantage in terms of passenger comfort, especially when you start putting 4-5 adults in there and overall space for personal items.
The front locker is also an advantage for rock crawling, but likely a disadvantage to the Torsen diff in the Raptor for high speed desert running
Don't get me wrong, I do not think the ZR2 is a better truck, if I did I'd have pocketed 25k and got one instead of ordering a Raptor. For me, the Raptor is the whole package. I wanted a larger truck for road trip comfort. I think it's by far the best looking truck on the road and as with most people, the majority of my driving will be on-road. The 450HP with the 10 speed will make it a far more engaging drive than the anemic by comparison V6 in the ZR2 much less the diesel.
If the Raptor didn't exist, the ZR2 would probably be next on the list.
fx4210
St. Petersburg, FL
um... but the ZR2 is ugly as sin...
If I can afford both comfortably I'm going to get a Raptor.. who isn't?
Also if I wanted the best offroader I'd get a jeep and a comfy pickup...
Otis857
Glendale, az
I dont agree that the Colorado takes the crown, but,... Our company has had Rangers, S-10's, first gen and 2nd gen Colorados in our fleet. All but the new Colorados were glorified tin cans. When we got the first new Colorados, we had a chance to put one up on the lift and really look it over. Gotta Say, Its a nice looking truck from a lot of perspectives. The frame looks stout with good crossmembes, Rear end doesnt look so tiny anymore, gone are the tinny doors that tear out at the stops, and its finally big enough to be comfortable.
Glad to see an American truck that delivers the goods to take on the Tacoma. But challenge the Raptor, that's a pipe dream! Now I hope Ford steps it up on the new Ranger too! Wouldnt it be great to see both Chevy AND Ford unseat the Tacoma in the small(er) pickup catagory.
Bluehinder
Traded my ZR2 after two months for a 2017 Raptor. The difference is so great it's not even worth of discussion.
Hated the ZR2, love the Raptor. One of the best vehicles I've ever owned, reglardless of class.
jikjak
Canada
I dont think this is a proper comaprison. The Colorado should be compared to a Tacoma TRD Pro.
Anyways, isnt the torsen front differential standard on the raptor? I dont remember seeing it as an option when i ordered.
jabroni619
It's an option. You can order it as a stand alone option and it's also part of the 892a package.
Members online
93,171
56,440
jumpcutter
