andreas.borgmann
- Joined
- Jul 22, 2018
- Posts
- 3
- Reaction score
- 0
Which leveling kit / air Suspention would you guys recommend ? Towing a 22ft race trailer.
I put an airbag kit on my 017 and transfered it to my 018 and it works great!
The bags have inner jounce bumpers for bottoming and the bags rest in centering cups so if you do use the travel they wont rip apart or limit travel, but will lift off the lower cup if travel is large and recenter when the truck comes back down.
I did a write up on it awhile back and Ive had two others who installed the same setup with posative feedback.
A distribution hitch is the best option but in my case Im running a custom toyhauler with a very heavy tongue weight due to its geometry.
I tow at 80 mph fully loaded 3000lb trailer, two full HArley dressers, full 50 gal water tank and bed of truck loaded and 4 peole in truck. Stable on all fronts.
Flip my outfitter switch on and put 20 to 55 lb in the bags for whatever ride comfort and load Im towing...when Im done, zero out the bags and Im on stock suspension.
re running heavy tongue weight: There is alot of conversation about exceeding tongue weight, saftey and the rear cant handle the extra load..My take is that the rear in this truck was designed to land 5500 lb at drops of 6ft and greater..Im sure the Ford engineers did thier Finite Element analysis and the loads from that kind of impact would far exceed a more than a few hundred lbs over numbers in a data sheet! With air in the bags, Im sure the air spring equivellancy is equal or exceeds an F250 rear spring properties.
