Air Lift rear kit installed for towing
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by WARP6, Nov 23, 2020.
  1. WARP6
    WARP6 Member
    39
    12
    Aug 18, 2019
    NC
    I just completed the installation of Air Lift Load Lifter kit for the rear of my 2019 Raptor. Rear bags are Load Lifter 5000 kit #89413 along with the WirelessAir EZ Mount compressor and manifold kit number 74000EZ.
    The rear bag installation went just as the directions showed with the exception of not using their brackets for the parking brake cable as my 19 Raptor has the electric parking brake. You do have to swap the jounce bumber strike plate/spacer blocks that rest under the springs. You put the left on the right and the right on the left. This is for clearance of their air bag mounting plates. Also, I opted to grind/clearance the short shoulder to clear the brake line brackets that are welded to the axle tube. Or, you can cut the brackets off and not grind the blocks. I didn't want to remove anything welded to my truck. So, I ground a small section off the blocks and painted them up real nice.
    I mounted the compressor/manifold/controller to the outside of the passenger frame rail using their 5/16 self tapping bolts. They include a nice large u-bolt to clamp to the frame but, I think that's more of a generic parts that doesn't really fit the Raptor's beefy frame. When installing the self tapping bolts, I placed the assembly up on the frame rail and decided where I wanted it to go, made a few marks the drilled the holes 1/4" using a right angle drill. If you don't have one, get one and some shorty drill bits. I actually used a step drill bit because I didn't have any bits short enough. Use a bit that's around 1.5" long or so. Then I used some cutting oil on the threads of the self tapping bolts and eased the bolt in and out a little more "in" each time until the threads were in clean. You might be able to run a tap in but it's stupid tight in that area. I used my Milwaukee ratchet back and forth, back and forth back and forth until the bolt was seated. Then I removed the bolts, cleaned the holes and bolts then put some loctite red on the bolts and put them back in.
    I ran the wiring through the frame and up into the engine bay. Red wire went to my Aux1 upfitter and black wire went to firewall ground. Do not connect pink wire to anything. Directions are misleading, don't use the pink wire that's supposed to go to key-on hot wire. It won't work.
    Routed air lines up over and through the frame rails then out at the controller.
    Their little hand-held controller that came with the kit is real slick and works great. The app not so much. I can't get it to work for me.
    I haven't run my manual fill lines yet as I'm still playing with the kit. I'll find somewhere around the rear bumper to mount them but I'm not drilling holes in my bumper or cover.
    Kit works great so far and suspension travel feels good when decompressed and tight when filled. I guess I need to jump it to see how it behaves!
    Ciqir and CoronaRaptor like this.
  2. CoronaRaptor
    CoronaRaptor FRF Addict
    17,006
    5,421
    Dec 17, 2012
    CANADA
    Where's the pics? Sounds like a semi-complicated install. Did it come with new U-Bolts too?
  3. WARP6
    WARP6 Member
    39
    12
    Aug 18, 2019
    NC
    I have pics but didn't have time to resize them for posting here. It did come with new U-bolts
  4. WARP6
    WARP6 Member
    39
    12
    Aug 18, 2019
    NC
  5. WARP6
    WARP6 Member
    39
    12
    Aug 18, 2019
    NC
    a mini-sawzall worked great to cut the brake line bracket. Painted the raw ends brake line bracket pre cut resized1.jpg brake line bracket post cut resized1.jpg
  6. WARP6
    WARP6 Member
    39
    12
    Aug 18, 2019
    NC
    brackets going in
  7. K223
    K223 FRF Addict
    2,748
    1,177
    Sep 15, 2019
    Florida
    I hope more to come
  8. Zilla
    Zilla Member
    43
    18
    Feb 18, 2019
    San Jose
    Great write-up. You will be very happy with this setup. I did the same thing last year and haven't looked back. I will say that we also installed the Daystar cradles so that the bags arent bolted down a the bottom. Still get full movement when offroading, then i can air up when I want to tow...there are a few writeups on the forum where I saw this done and copied it.
  9. WARP6
    WARP6 Member
    39
    12
    Aug 18, 2019
    NC
    Zilla, thanks for that info I didn't know existed! I'll definitely be researching that.
    More pics to come as time allows
  10. codeman
    codeman Full Access Member
    82
    74
    Nov 2, 2020
    Canada
    Interesting. Wonder how this would work with any off-roading? Seems you could set it to a low PSI and use it almost like a bump stop as well, or am I mistaken? Seems like a really cool idea
Share This Page
