Squatting Dog
With Texas Raptor Run coming, I started to install LGE/CTS upper shock mount reinforcement plates.. When I loosened the upper rear shock bolts, I noticed there was no upward pressure from the shocks. Both rear shocks were completely flat, meaning I could compress them fully and they stayed compressed.. So I contacted several people including the vendor about this issue.. Seems across the board (fox, king, icon) these shocks can and will loose nitrogen pressure over time.
So now that you read all this, what is the point? Since the pressure loss is gradual you might not notice it right away.. So check your pressures in your shocks before you go out in play, just like you would in your tires..
-Greg (aka squatting dog)
