GEN 2 ADD Stealth Front Bumper and Oil Change
Mesa, AZ
I’m 6’3” and with the king 3.0 setup on mine I had to use a small step stool to get it relatively easily but it was a tight fit for my arms
Yes you will need a step of some kind. The oil re-direct that is built in from Ford works well. I happen to have one up on the lift today so I snapped these pics just now.
Mesa, AZ
Your new ADD Pro Bolt on bumper has a removable skid, does it not? I just received mine and the bolts on the skid can be taken out.
All of our bumpes have removable skid plates, I said I dont know of any bumpers that have an opening in them for the oil. As pictured above, the built in oil re-direct spits the oil out on the side of our bumper.
brettmess24
I’m going out to do mine right now!
Nasty out so I’m going to get dirty anyway...
Otis857
Glendale, az
I dont know about Gen 2 or the stealth bumper skid plate, but I have a Venom bumper on my Gen 1 and I can get into it easy enough from the bottom on the side of the skid plate. Not as easy as the stock plate, but not that much of a problem to get to the filter.
brettmess24
Don’t get me wrong I absolutely hate changing the oil on this truck!
The vac takes out a little more than 2 quarts and the rest doesn’t shoot out as bad and I was able to move the pan around with little loss.
Also showing the little bit I use to remove the drain plug.
I
ICEMAN 316
I got rid of the bolts and nuts that hold the skid plate on and replaced them with u-nuts that way the skid plate can actually be removed for oil changes. I learned the hard way after having the honey badger and having to change the filter from the engine bay
I think the u-nuts are the best solution. Don’t know why ADD didn’t just use them or they could’ve welded the nuts too.
2019 | Ford Performance Blue |
93,180
56,460
khunter
