Raptor911
So the 2021 Raptor has 3 wheel options:
- Base
- Beadlock
- Beadlock with 37s
Anyone know the offset of the wheels above?
- Base
- Beadlock
- Beadlock with 37s
The 37s wheels are 30mm offset so it is 4mm push outward when compared to the other 2 wheel offerings on the gen3. Venomrex is 12mm so compared to the 34mm wheels. It is 22mm pushed out when compared to the 34mm offset. I hopes this makes sense.I noticed from the "Keep it Dirty Off-Road" video https://www.youtube.com/watch?v=nqZ22OftsH0&t=9s that they talked about the 37" wheel being offset more outward than the Gen 2 stock wheel. Wasn't the Gen 2 stock wheel a 34mm offset?
I also ordered the stock wheel on my Gen 3 35".
So if the 37" wheel is a 30mm offset then does it move the wheel outward by 4mm?
How does the 37" compare to my VenomRex 602's with a 12mm offset & 5.5" backspacing?
Thanks, I have a hard time understanding this subject!!
Any idea if a 325/60/20 tire would work with a Venomrex 601 without any issue? Thinking about a Nitto Ridge Grappler or BFG KO2:The 37s wheels are 30mm offset so it is 4mm push outward when compared to the other 2 wheel offerings on the gen3. Venomrex is 12mm so compared to the 34mm wheels. It is 22mm pushed out when compared to the 34mm offset. I hopes this makes sense.
Search the GEN2 post. On the GEN2 I am pretty sure you needed a slight lift to clear a 20" wheel and tire combo. Not sure if the GEN3 will require the same.Any idea if a 325/60/20 tire would work with a Venomrex 601 without any issue? Thinking about a Nitto Ridge Grappler or BFG KO2:
View attachment 318562View attachment 318563
On my 2019, I ran Titan7s (17x8.5 with a -1 offset) and I was rubbing at full lock ... very light rubHow would an 18x9", 110 centerbore, -1 offset wheel fit when compared to the +30mm offset of the 17x8.5" OEM wheel?
Update:
Based on some research, the 18x9, -1 offset wheel would stick out about 37mm more than the OEM wheel with the +30mm offset. That's almost 1.5 inches which could cause some rubbing issues.
