Sendit6creed
Howdy yall,
Have a race red 2013 raptor. 60k on the miles, never offroaded and generally babied.
Get home from driving into houston and noticed my left headlite no longer lines up seamlessly in its recess. Facing the front, the right side of the lite is about .25 inches awsy from the side of the recess. Same at the bottom. Pax side is perfectly aligned. Was not out of alignment prior to making tne short drive. Also was not hit or bumped.
Looking at the upper mounting fender screw under the hood i can see where the fender panel moved. Im guessing bolt had loosened a bit and the ****** houston roads may have jarred it out of alignment.
Any suggestions or experiences with this by any of yall would be welcomed.
Thanks in advance...
