Rubber Body Panel Plugs
TAC71
Osoyoos BC Canada
Would need to pull them all to check...but... I think there is 16 or 18 that are the same, about
1 9/16" .
4? That are rectangular and 2 that are larger...1.75"
I found rubber plugs for them all.
Jhollowell
Everett, wa
Ohhh wow. Didn’t realize there were that many and that they are round. Might not be as cheap to make plastic plugs now. Especially if they are round as i don’t have a way to hold round stock on my mill
Augster
Sandy Eggo
I replaced my OEM tape with Gorilla tape, which I think would be just fine out here in the dusty, dry Southwest...
Irregular F150
its terrain good sir!
a small town in way up northeast
Chzhead
Chzhead
Wisconsin
Well I guess this is on hold for me. Just heard from my dealer and half my order is on back order........sigh. Maybe back to the drawing board.
Chzhead
Chzhead
Wisconsin
Well, after several weeks of waiting I finally got some of my order in (bolded).
Here is my order:
-W651021-S, 45MM
-N802981-S, 38MM
-W651012-S, 18MM
-383181-S, .75"
I can confirm that there are 7 N802981-S plugs per side. The very first hole behind the front tire is just too big for the 38MM (easily moves around) but too small for the 45MM. I used 2 of the W651012-S plugs (trimming just a bit) for 2 holes buy the step bar mount (1 per side). I have not pulled the tape but there should be 2 383181-S plugs, 1 per side as well. I can't confirm until I get those. Near that hole there is also a square hole that I have not found the part to yet, that is covered by tape as well. I had to duct tape for now (as its mid winter) to try to keep the holes plugged until spring......or until I find longer dry time/no snow!!
1 nice thing, when I pulled the rear tape the sunroof drain hose was right there so I poked a hole in the plug and now I have it draining OUTSIDE the cab.
vtwinjunkie
va
Here is my order:
-W651021-S, 45MM
-N802981-S, 38MM
-W651012-S, 18MM
-383181-S, .75"
Can you post how many of each you used in your list?
it looks like:
W651021-s qty ?
N802981-s qty 14
W651012-s qty 2
383181-s qty 2
Its a bit confusing since your description did not list any of the W651021-S , yet it is on your order.
Also any updates since last time?
I might try to make an order
93,224
56,503
DehydratedSurfer
Latest posts
