Installing We Boost
ckg26
Colorado
Hi there
I am looking for some guidance on what others have done to hardwire their cellphone boosters. I am going to mount on the bed. Just trying to figure out how to run the wires and hardwire in the auxiliary swithches.
Thank you in advance.
jm77
USA
Hi there
I installed a Weboost in my gen3. I used a bulletproof diesel 3rd brake light mount for the antenna. It’s powered from Aux6 so I can turn it on and off as needed. Weboost sells a hardwire adapter. I mounted the unit behind the rear seat. It actually slides right under the subwoofer perfectly. I’d highly recommend spending the money for the bulletproof 3rd brake mount. Easy install, well made, and looks awesome. Weboost sells 2 different NMO antennas. I use the low profile day to day and the larger for trips.
Running the wires is pretty easy. From the front passenger kickpanel you can pull the wires to the back through the existing wire channel. Getting the antenna cable to the 3rd brake light is also pretty easy. The wires can be just tucked into the headliner where it meets the back window. Don’t need to pull the headliner down at all. From there tuck it into the back corner of the C pillar.
RotorOver
Greater Atlanta
A great solution for any antennas!
sharkhunt
Did you have to use an adapter from the weboost antenna conection to the pl-259 that comes on that 3rd brake light mount? I remember running into this the last time I tried to use that mount for that purpose.
jm77
USA
Yes, believe it was 2 different adapters I used. Maybe not optimal (I’m no expert) but seems to work (also checked continuity).
sharkhunt
I remember having hell trying to find the correct adapters. At least I know it’s possible now. Hah.
jm77
USA
93,180
56,460
khunter
