Carbon Cartel steering wheel
amp
TX
After sitting in my garage for about a month, I finally got around to getting the Carbon Cartel wheel installed.
I chose the flat top and flat bottom wheel, but decided against getting the carbon trim insert. Didn't like the look when you have 2 mismatched carbon fiber pieces next to each other. It's hard to get it right unless the weave is the same, and flowing in the same direction.
The heating function was disconnected since the new wheel doesn't support it.
Todd Turbo S
Nor Cal
Love that CF wheel, if the heating function worked, I’d buy one tomorrow.
A
amp
TX
What’s that screen? Can we see a close up?
Yeah, it's the Phoenix Android screen.
Basically an Android tablet with a custom trim that fits into the console. The 3 buttons get relocated to the top, and you lose the physical volume and tune dials, and they become digital or you can use your steering wheel controls.
Raptor50
CO
Hows the quality of the CF Steering Wheel? Just installed a Porsche OEM CF Steering wheel in my Macan Turbo and love it (took me a few months to work up the nerve to swap it myself, turned out to be the easiest mod, less then 30 minutes)! So I've been researching options for the Raptor. Did you install the wheel yourself?
Joe R
Maryland
Because the heated steering wheel function is disabled is probably why I’m don’t buy for my Raptor!!!
A
amp
TX
I wasn't that comfortable taking it apart and getting it aligned correctly, so I had a local shop take care of it.
They really did a good job with the flat top and bottom. The bottom flat length is longer than the top flat length, and also the transition from the curved part of the wheel to the top flat area is very subtle. The bottom flat area transition has a more noticeable edge to it than the top, but it's nothing sharp at all. The CF quality is nice, and doesn't appear to be any different than the rest of the CF quality in the truck. I'm also still able to see the dash instrumentation through the top part of the steering wheel OK.
It was worth it IMO. I'm not a fan of how a leather steering wheel ages and gets shiny over time from just regular wear. Most of the surface that I grip is the CF, so the leather tends to last longer especially on a daily driver. I've had CF wheels installed on a few of my other cars, and they've all held up well.
