ShadowRaptor
Not sure if you guys already know this, But Just thought I share.
I needed access to the oem pass thru wires, and to the upfitters so I was poking around under the truck and I found, what I think is a good access point (avoid drilling) from the rear/ bed area to inside the cabin.
Theres an existing OEM hole for the factory harness clip. Its located just below the right/ rear passenger area.
It can be accessed once you remove/unclip the door sill trim moulding. Then look all the way to the rear and unclip an existing plastic wire harness clamp ( see pic)
Also, underneath the door sill/ trim mouldings, there’s an exisiting wire harness channel/groove, that runs all the way from rear passenger area to the front, where the pass thru wires are located.
This made it easier for me to connect to the aux pass thru wires and eventually use the upfitters for lights, etc.
Anyway, hope this helps someone, somewhere, lol.
