GJ Motorsports 3rd Brakelight
renegadeagle
Puerto Rico
Tested but seems to be backwards the led circuit of harness .Braking are dim and running light very bright.
The adapter seems to be have sent wired wrong
renegadeagle
Puerto Rico
@renegadeagle we reached out to both TJ and Keith during our install w the exact same pictures Figured the instructions would have been updated as very common. Hope the rest of the install goes better.
Actually the leds seem reversed.Running lights are super bright and brake light is dim..Frustrating
4x4TruckLEDs.com
I reached out to Tom (GJ Motorsports) for ya to inquire about that reverse brightness issue. Maybe he's experienced it before
4x4TruckLEDs.com
Okay give this a try. Swap the blue and red wires on the factory harness. Some modules had the polarity reversed (as you suspected). That should get you back up and running.
4x4TruckLEDs.com
Ordered the kit for my 2010 Raptor Received the kit for 2017 Raptor. Contacted 4x4 Truckleds and told me to send back everything including harness. Now received correct assembly but the connector on harness does not plug on truck.Attached photos.Almost a month between all this odysey .All the routing of cable done on truck already.Very frustrating.
For the money would have expected honestly better customer service.
Truck connector,original from OEM
to original brake light, on left 3 pins.Harness connector on right.4 cables and connector does not plug to truck.
I am sorry about getting the wrong bracket sent out. One of my employee's, who's honestly not as familiar with these kits as I, picked the wrong box and didn't think to read the pick ticket properly. So he sent out the Gen2 kit instead of the Gen1 kit. We did get you a pre-paid return label for the wrong kit and once we got it back I personally made sure to send out the right one. So from the time you got the original order it was just under 2 weeks for you to get the right one.
As a sign of good faith I've gone ahead and refunded your order an additional 5% of the original total. Hopefully that little extra money back in your pocket helps make up for the mix-up. My pick/pack guy also apologizes for messing up the shipment.
Chiefapple
Milwaukee, WI
Well shit. I never checked till now, but my brake and running leds are backwards also.
4x4TruckLEDs.com
Well at least we all know how to fix this now IF you experience that issue. I never knew about it myself and it seems like there might only be a FEW kits out there this happened to
