Performance Blue Owners Pictures
Kashoggio
Lives in a van down by the river.
Road between Paso Robles & Cambria?
Sent from my SM-N960U1 using Tapatalk
Actually it’s Whiteface mountain up by Lake Placid NY
19RaptorPB
Virginia
Finally installed the Eibach springs, lights, and completed the first oil change...
19RaptorPB
Virginia
How did that spring compressor work out for you? Just ordered one. Looks a little tweaked in the pic.
It actually worked out pretty good. It’s not tweaked, rather meant to work that way to follow the coil. I’ve used the standard in line compressors (up to four) on one spring and I would use this over those any day. This would obviously be beat out by the wall mounted hydraulic press but honestly it was well worth the money I paid for it. OTC makes good pullers etc which is why I bought this compressor. I think anytime you compress a spring there’s a small bit of pucker factor but I was definitely way more comfortable with this one.
Mk1 Caddy
Thanks man, what about the bottom shock bolt torque? I know its been discussed before but my Dewalt electric impact is rated to well over 400 ft lbs (or whatever the torque spec is) dont want to break anything.
19RaptorPB
Virginia
I used my old air gun which is probably about 300ft lbs and then I put a cheater bar on it and tightened it by hand. I had to break it loose by hand as well.
93,202
56,485
bjorn-dpc
