It is DONE!. Started my B&O replacement stereo install.
pbtjrlmrt
Oregon
I used a JL Fix 86 instead of the Nav-TV...wish I would have used the Nav-TV
I also used a JL TWK88 for tuning the sound...you'll want one of these!!!
Other than that I used Focal top end front and rear
I used 2 JL audio 10" subs for the rear and the same JL HD amp.
I was able to install it all behind the rear seat saving the entire floor space and not having to cut up the floor mat.
Sounds great...hits hard with the dual subs...JL does an amazing job with their thin line subs.
I also did the sound mats in all the doors
goblues38
goblues38
STL
did the final edit on post #4. I am done with the install. very please. The B&O system sounded fine at lower levels. fine for background music when family was in the truck. But any time I wanted to open the windows and the sunroof and "rock out" as I decompress on the way home from work, the sound just did not cut it.
No more. Windows and roof open at 70mph, and I can hear and feel :) every note. So happy I broke down and did this.
Cant stress enough how awesome the NAV-Tv A2B device is. I would not have done this without it. High level inputs to an amp is like seeing your mom naked. It's just gross to me.
goblues38
goblues38
STL
Stopped by the local shop where i bought my parts from. Got 2 thumbs up from them. They were impressed by the Nav-TV A2B device as well.
So now I am done with my truck.....for a few months until the next upgrade bug hits me :)
pbtjrlmrt
Oregon
What did you use for a DSP? I used the TWK 88 from JL Audio. If you didn't use a DSP then you are missing out on half the potential of your new system
goblues38
goblues38
STL
I am old school. Flat 4 channel stereo comes from the NAV TV A2B. Popper tuning of the system gives me just fine imaging. I have no use for time delays in the car.
I may add an audio control EQ at some point, but for now, everything sounds great. I am not interested in DSP to artificially change the sound stage to be "driver" focused. It is set up now using old school techniques to be "front seat" focused, and that is all I need.
carmelk6
NC
Reserved for power wire and sub box. (edit 6-19)
here it is with carpet, but before I cleaned it up
I will take more pictures tomorrow.
For the box did you use polyfil? Install a port? Use any sound deadening material on the inside?
goblues38
goblues38
STL
Sealed enclosure. Glue in all the joints + silicone. I put in a small amount of poly fill just to knock down any problems inside the box.
It is a big pick up truck made of plastic, large sheets of metal, and other materials. It would be impossible to make that truck "quiet" without spending a fortune of materials. I chose to leave it as is.
Been driving around for a week now, and I have "no regerts" :) If the truck get's noisy, i now have plenty of volume to drown it out.
But seriously. Normal driving with the family in the car. music is playing quiet in the background. it just sounds like a truck, i knew that going in.
pbtjrlmrt
Oregon
It's not about "driver" focus or time delays...do you even know what a JL Audio TWK 88 is? You sound like you know what your doing and to characterize a DSP like TWK88 as something used for only driver focus or time delays sounds uninformed to me. You mentioned EQ...well...the TWK88 does that and many other things for you. I get it if you just want flat sound but the TWK...and other products like it will add another dimension to your sound thats all.
ddpt
NAV-TV interface - is it seemless
Sent from my SM-N960U1 using Tapatalk
goblues38
goblues38
STL
As I said....this is my first install in 30 years. So no, I am not aware of that piece. Just like in my home audio, i don't like room correction or delays. A properly set up system doesn't need that. And again, "perfect" was not the goal of this system.
yes. You never know it is there.
93,202
56,485
bjorn-dpc
