Aftermarket Wheels/Beadlocks
MRxGREEN
St. Louis, MO
I bought the ford OEM beadlock capable wheels from the ebay seller. My plan is to have the dealership switch them out when my Raptor arrives. My question is do I need anything besides the wheel? I have the beadlock wheels and they came with nothing, just the wheel. Does anyone know if I need anything extra to get them on my truck? Can the parts from the standard wheel be used for the beadlocks?
*This is my first time switching out wheels on a vehicle.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
Your TPS should transfer. If you want beadlocks you will need to buy the rings from Ford. Assuming the lug nuts will fit the wheels.
MRxGREEN
MRxGREEN
St. Louis, MO
The seller said TPS would transfer. Lug nuts, wheel lock, hub cover? I assume those are on the standard. Would they transfer?
crash457
I'm Batman
St. Louis, MO
Lug nuts/wheel locks/TPMS will transfer over. I think the center cap will as well. Did you get the trim rings with the wheels?
MRxGREEN
MRxGREEN
St. Louis, MO
Thanks crash. Helps ease some nerves. The trim rings? If you mean the rings that actually allow it to go full beadlock, no I did not get them. There is literally nothing in the box except the wheel.
Lex
San Diego, CA
Are you talking about the seller on Ebay from Detroit Wheel and Tire? I'm also thinking of buying a set from them.
MRxGREEN
MRxGREEN
St. Louis, MO
Yes. I talked to him and he said I shouldn't need anything else. But I want to be sure since I am not super experienced in this area.
Bullishone
Wow guys this is actually a smoking deal;
http://m.ebay.com/itm/182413053763
---------- Post added at 10:25 AM ---------- Previous post was at 10:24 AM ----------
No idea how he has so many, but if you want Beadlocks these are the ones to buy ^^^
RaeGun
Here is my new Raptor with the older style '14 Raptor beadlocks. I think it looks great. I was going to powder coat the rings to match the fender but decided to stick with the machined aluminum look. Perhaps not for everyone, but I kinda like it.
[/URL][/IMG]
PropDr
Eugene, Oregon
If this are OEM wheels, there have the trim ring mounted.
I would recommend to remove the trim rings prior to mounting the tires.
If you intend to install them in bead lock configuration you need to get the forged bead lock rings.
93,180
56,460
khunter
