NEW PRODUCT ALERT! * HPA Air Systems by KSI Engineering *
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
NEW PRODUCT ALERT
Have you been looking and waiting for that next-gen air supply system? Tired of the high cost of Co2 tank refills? On-board air compressor on the fritz?
Well look no further! Here at Haynes Offroad, We are very happy to announce that a brand new portable air system has hit the market! We have had the pleasure of working directly with KSI Engineering for over the past year to bring the next big thing in portable air supply to the public!
We are very excited about these as they are extremely light weight, functional, very safe, has multiple benefits over Co2, and not to mention just plain cool looking!
*Please note, all picture are pre-production and final units may vary slightly*
So what is a HPA Air System?
HPA stands for "High Pressure Air". This is NOT just a compressed air tank or a Co2 tank.
HPA Systems are made with cylinders utilizing some of the
safest designs available anywhere. While other systems use just aluminum cylinders, our aluminum
cylinders are wrapped in carbon fibers for maximum strength and then fiberglass fibers for superior
toughness.
These are currently scheduled to be available for PRE-ORDER on December 1st and will feature a special promotion!
Please feel free to ask any questions, there is a lot of information available to share.
6.8L HPA System *Estimated Retail pricing $649*
System Specification:
- Volume: 6.8L (416 ci.in)
- Approx System Dimensions (LxWxH): 22” x 8.5” x 8.5”
- Approx System Weight:
a. Empty: 16 lbs
b. Filled: 20 lbs
- Operating Temperature: -4 to +140 deg (F)
- System Output Pressure: 0-250 (+/- 3) psi Adjustable
System Includes:
1. 6.8L Carbon Fiber Composite HPA Storage Tank
a. DOT Approved
b. 5yr Hydrostatic Test
c. Paintball-style type fill valve
d. Pressure Gauge
2. Flat Surface Mounting Bracket
a. Positive Locking Strap
b. Roll-Bar Mount Available (Sold Separately)
3. Pressure Venting Adjustable Regulator
System Advantages:
1. Safe for the Environment & Operator
2. Nitrogen Capable
3. Tire Inflation, Shock Inflation & Air Tool Capable
4. Universal connection allows for the use of existing tools and airlines
5. 3 Safety burst discs installed
6. Pressure venting safety system
7. Tanks do not need to be exchanged when filled
WRCRaptor
Great Lakes
Ok so How do you fill it?
Give us some specks maybe like the Powertank site does. i.e. number of tires it can fill from lets say 15psi to 44psi or how long can it run a 1/2 impact at 90psi.
HAYNES OFFROAD
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
Good questions!
We suggest finding a local fill station prior to purchasing an HPA unit. Many paintball shops, sporting
good stores, SCUBA shops & Fire Stations can fill HPA systems. A good database on the web to assist in
your search can be found here:
Find a Fill Station
If you find a station, please consider adding it to the database for others to reference as well. If you are
having difficulties finding a fill station, please let us know and we will assist in any way possible.
As far as actual performance specs, we do not have the "official" number tables as of right now, but will be available soon.
With that said, unofficially, the test unit has seen 4 tire refills from 10-15 psi to 45psi and had approximately 1000psi left from full. Run time for air tools is tricky as there are many factors, running psi, tool CFM, etc... We will have some examples soon. The 6.8L tank is most closely comparable to a 10lb Co2 tank.
Deleted member 12951
I don't see anything protecting the valve (or top), like you see with C02 tanks. What would happen if the top breaks (looks longer than average). Will it become a flying missile? Or is there safety measures with this design to prevent that?
Cool link, unfortunately each place is an hour from me. :-(
Also, can you use this sideways or does it need to be upright like CO2? I assume if you use Nitrogen, it would?
WRCRaptor
Great Lakes
@RDFTS look for a paintball shop or scuba shop near you. I don't think all places are listed. I think there is a scuba shop close to me that is not on the list also a paint ball place.
---------- Post added at 04:06 PM ---------- Previous post was at 04:05 PM ----------
I also think the cost may be less compared to Powertank
dkfc13
HPA Systems LLC.
SE Michigan
I would suggest giving your local scuba dive shop a call. Most of them can fill paintball tanks.
I know there are a number of dive shops in SE Michigan and Google says there are a few in SW Missouri.
Ha. WG beat me too it.
93,202
56,485
bjorn-dpc
