jackrook
I got a knock off 120watt 20 inch LED bar. Which switch would work best??? 3? 4?
Sent from my iPhone using Forum Runner
mmm... sorry but title made me hungry. Which wich.... Couldn't resist.
120 watts / 12 volts = 10 amps. You could use #4 since it has a 10 watt fuse, but I'm curious to know if it will peak above 10 watts and cause you to blow the fuse. I'd run it on #3 to be safe.
Unless you are out of switches, just use switch #3. It is already fused and rated for 15 amps.
